gary635g
Am trying to install new Royal SS king pins in my 1950 but can not remove the lock pin from the Knucle 352655s the green book says to remove by moving it fwd meaning it would come out from the grease zirt side. I have moved it with a punch ~3/16" but it is locked up and I can not move it. Could the instructions be wrong? is it possible that it has to be removed to the rear? I could try to pound back in and see if that helps but thought some advice might be better than destroying the assembly. The new set uses split pins so I guess I could try to drill out if necessary. Thanks Gary
