If you still have the plate that is attached to the inside of the glove box door it will also give you the rearend ratio.( providing it is the original rear end).
49 Mercury and 49 F-1 rear ends appear identical except for the spring brackets which are on top of the housing on the F-1 and under the housing on the Merc. My Merc has the 3.91 gear without overdrive. My F-1 has a 3.73 which is about right for the 6 cylinder.
I checked the rear housing and there is a 41 on it, and the plate in the glooove box has model 9rc and the serial number on it.
I just bought a '50 F1 and I am doing my research and this thread sparked my interest.....
My truck has the 41 stamped with a W 51/13 tag. I also have a 4 speed transmission which hasn't been mentioned before.
Will swapping to a 3 speed help me a little or are you still convinced that a rear or gear change is necessary?
Thanks.
Thanks.
