Evil-Eric
Ok, so im not sure how this all fits together on a '50 sedan. Purchased new master with new bronze bushings....now I always thought bushings are a tight fit and need reamed. The new bushings slid in and out of master and slide on and off the pin f the brake pedal. Is this right?
Also after the brake pin goes through master there is a groove cut in the pin at the end that sticks out...is there something that attaches to this?
Ive looked all over for a diagram of the brake pedal assembly, with no luck.
Thanks!
-Eric
Thanks!
-Eric
