Just a bit of related information. While removing the transmission is not difficult, any clutch work complicates the process. This is because the bell housing is one piece, which will not allow access to the clutch unless it is removed. This requires the transmission to be removed first, and then lowering the rear of the engine to allow access to the top bolts on the bell housing.
The last time I did it, i was tempted to take a spare bell housing, cut it up, and weld some flanges on it so the bottom would be removeable (like a brand "C"). It sure would make life easier.
