1949 mercury clutch
jetmek
Will a 10” long clutch and disk work in place of the borg and beck pressure plate ? Ill be using a steel insert alum flywheel drilled for the 10”. Stock merc 3spd od trans Thanks
Borg and Beck design uses equidistant bolts spacing on the cover to flywheel. The Long uses two equally spaced bolts in three locations so spacing is different.
