1949mercury
Anyone find a good 12v fuel sending unit they like. Not the crappy plastic one that holds the sending arm ?
https://eclassics.com/eclassics-195...inless-steel-fuel-sending-unit-for-oe-gauges/ I found this is anyone is looking.
I believe the standard way of doing this is to use the stock gauge and sender with a voltage reducer before the gauge. Given the incompatibility of most senders and the poor quality of just about all of them, it should be a good reason to do it this way. It was good enough for Ford the first several years after they went to 12 volts.
It looks good but, if it operates on the OHM's principle it will be a miracle if it provides accurate readings.
Go with the voltage reducer as suggested. Cheaper.
If you in fact have a reducer on the gas gauge, this may be the source of the problem.I do have the reducers on my stock gauges and the gauge reads full when filled but it goes really fast to empty.
