1949 ford panel truck
rrob
New member
s. Berwick
ME
wanted frame and running gear for a 1949 panel truck. Have the body but no frame.
rrob, I had 2 49s, sold them both. Just keep lookin... You'll find one. Too bad your so far away. Stark Wrecking in Miamisburg, Oh. has 5 panels in there. Ken
I have a bare chassis with front and rear axles from a 1951 f1 pickup, includes title. The frame is the same on 48-51 for pickups and panels just need to change the runningboard brackets to mount the shorty panel truck boards. 52 will also work but ford made a small change in the motor mount braces and added a diagonal brace on the driver side from frame rail to trans crossmember. All these frames have the holes for the panel truck gas tank mounts.
I also have a very nice, solid bare 48 F1 pickup/panel frame here with just a front axle. no rot at all, can be had cheap. $250
