1949 Ford 8n Tractor
Heres my NAPA tractor cheat sheet I printed it out and it hangs in my local NAPA.
NAPA Ford 9N,2N,8N Tractor cheat sheet
Front Mount distributor...
Points: NAPA #CS35 or Standard Ignition Blue Streak #FD-6769X (Premium)
Condensor: NAPA #FA200 or Standard Ignition #FD-71
Rotor: NAPA #FA300 or Standard Ignition #FD-104
Distributor Cap: NAPA #FA350 or Standard Ignition #FD-126
6 volt coil IC7
6 volt voltage regulator VR950
GL-1 90w Mineral Oil Napa Part# 65-205
8N Oil Filter Napa# FIL-1010 or Wix #51010
Cyclone top mounted pre-cleaner gasket Napa Victory# G26410 or Fel-Pro# 11528
Steering Sector Oil Seals NAPA Part Number – 11055
Sediment bowl neoprene gaskets NAPA/Balkamp "O-ring" p/n 730-9506
Marvel Shebler Carb. Rebuild Kit NAPA KIT #2-1401
8N Head Gasket NAPA# NGA-1950
Welch (“Freeze”) plugs, 1-13/16” NAPA 219-1021
4 brass nuts for exhaust manifold: 7/16-20 x 5/8, NAPA part number STN104X.
4 brass nuts for exhaust manifold: 7/16-20 x 5/8, pack of 10 from Fastenal p/n 1175115
4 studs for exhaust manifold: 1-5/8 long 7/16-14. NAPA part number for a 1 ¾” stud
(Handi-Pack item) is RFD 86644. (stud is longer than OEM so make sure it does not
bottom out in the block) The 2” stud is p/n 86632 which can also be used.
Fel Pro Gaskets for N’s,
Head Gasket 7277B
Head Set HS7277B
Full Set FS7277B
Manifold Set, Intake & Exhaust MS8782B
Oil Pan Set OS 2916D
Valve Cover Set VS2976
Timing Cover Set TCS 2921
Carb Mounting 8783
SEALS
Chicago Rawhide/SKF part numbers
Governor seal # 3683
PTO shaft seal # 16189
PTO shaft seal Speedi-Sleeve # 99162
Transmission input shaft seal # 13568
Transmission input shaft seal Speedi-Sleeve #99138
Outer Rear Wheel Seal 8N though S.N. 486752, # 24986
Outer Rear Wheel Seal 8N from S.N. 486753, # 27426
Inner rear Wheel Seal 8N # 19831
BEARINGS
Front Wheel Inner, # BR15118 Cone, # 15250-X Cup
Front Wheel Outer, # BR09074 Cone, #BR09196 Cup
Clutch Pilot Bearing, # 6203-ZJ
Complete throwout bearing/carrier assembly, # N1425
Throwout bearing only, # N1087
Throwout bearing only, regreasable, # N1167
Differential side bearings, # BR3984 cone, # BR3920 cup
Pinion bearing, front and rear, # BR53176 cone, # BR53375 cup
Rear differential pilot bearing (straight roller bearing) # RS5305-W
Transmission countershaft bearings, # BR25877 cone, # BR25820 cup
Inner bearing, CNH 86609936 Timken 15118
Inner race CNH 86577043 Timken 15250X
Outer Bearing CNH 86576860 Timken 09074
Outer race CNH 72063 Timken 09196
Good place to get parts and info
https://www.just8ns.com/
Please be more specific - which "Ford Gray"? And are you restoring a 9N/2N or 8N? If a 9N/2N, are you going back to the original "battleship"/dark grey monochorme look used from '39-'47, or the "redbelly" '48-'50s 8N look that dealers loved to use to make the older tractors cosmetically look like an 8N, which used an olive-grey on the tin and Vermillion Red on the engine/running gear? Plus there's different grays used from '57-'62 and '63-up, with the '60s Grey being almost whitish. I have Ford M-#'s for all of them but won't be able to post until tonight.
For wheels (rims and centers) and wheel weights, I used a spay paint color that matches, pretty well. The color is pewter.
From http://www.ntractorclub.com/forums/nhistory/messages/2398.html (I've added the Ford M-#'s and a few others)
GRAY Paints:
9N-2N (DARK) GRAY: M-1778-H, M-13243
TISCO - TP230 Ford Dark Gray
Martin-Senour - 6019 Ford-Ferguson Gray -available at NAPA
NAPA - 991 21200 Gray
Cote-All - AZ-0405 Tool Gray (made by Diamomd Vogel Paints, Orange City, Iowa)
NAPA - 99L3732
8N GRAY (Olive Gray): M-13243
PPG DELSTAR - DAR 31657 (OLD DITZLER NUMBER)
TISCO - TP240LF FORD MEDIUM GRAY
CNH - NEW HOLLAND GRAY
8N RED: M-2822
TISCO - VERMILLION
TISCO - TP310LF FORD RED
TISCO - TP480LF NH RED
TISCO - TP110LF IH RED
PPG OMNI AU (MTK) - 3794;
ALT OEM CODE: 81, WA8774, WA784 - GM BRIGHT RED
DIAMOND VOGEL INDUSTRIAL - 141959 RED
CNH - NEW HOLLAND RED
RUSTOLEUM - SUNRISE RED
PPG-Ditzler - DQE-70801
SILVER: M-1J-23 - Ford Argent Silver (Original Rims were Silver Cadmium Plated)
CASE/IH SILVER ARGENT. Used on rear hat rims.
RUSTOLEUM METALLIC SILVER
PPG-Ditzler - DEE-45 Argent Silver/Aluminum Metallic
BLACK:
For N-Series Pan Seats-
TISCO - TP550LF GLOSS BLACK
AGCO - GLOSS or Semi-Gloss Black Enamel
Radiator: Use a semi-gloss black heat-resistant paint. Local radiator shops carry it.
...and from YesterdaysTractors.com
https://forums.yesterdaystractors.com/viewtopic.php?t=1358655
Here are some OEM equivalent paint codes that may help
Ford Tractors 1948-1957
Grey (Medium)
Ford Paint Code: M 13243
Tisco: TP240
PPG: 32675
Centauri: 250202
Van Sickle: 457
Martin-Senour: M2J957
Red (Vermillion)
Ford Paint Code: M 2822
Tisco: TP480
PPG: 70075
Van Sickle: 480
You can also go here:
https://paintref.com/cgi-bin/colorcodedisplay.cgi?manuf=Ford&model=Tractor
Bought some great parts from Dennis Carpenter and the quality is really good. Went online to a couple places and good response for help.
Bought paint also from Dennis and the color is almost perfect from the original. Good stuff !
Thx....Mike
