1949 F1 ******
rol1949
I have a 1949 F1 with a 4 speed on the floor. I would like to put in a synchro shift transmission to replace the old double clutch type and a grinding gear type of old ******.
Does anyone know where to buy one and approximate cost?
Thanks,
Rod
Ebay and Craigs List are two places you can check in your area. There are plenty of old Ford three speed, top loader transmissions around but most will need a rebuild. Many choose to go to later types such as a T-5. Do a search here, there is plenty of information.
Also, if you post where you are someone that lives in your area may be able to help you find what you need.
Some of those early Ford flathead 4 speed truck transmissions have the so called hogshead that is easily adapted to a later transmission. I just made a simple 1/2 inch aluminum flat plate and bolted it to the hogshead and to the later full synchromesh ****** with overdrive. The shifter hole on the floor hump even lined up in the same place. I had to change the clutch disk to match the donor ******.
If you can post a picture of what you have it would be easier to give you some suggestions.
Most F1 pickups came with 3-speed but the 4-speed was optional. The later type synchronized 4-speeds are out there but they are bigger and heavier so some mods would be required. The light duty 3-speed was common but only 2nd & 3rd are synchronized. Less common are the heavy duty 3-speed but there are likely still a few of those out there too. They are harder to find and they are larger than the light duty.
I have a rebuilt 3 speed out of my '48 F1 that I'm not going to use. As it is used as a truck I wanted the low 1st gear but not the "crash box" so I installed a T5. Only trouble is shipping would be expensive depending where you are located.
Unless you find a trans out of an F-1, either the "light duty" 3-sp or the HD 3-sp, major surgery is required to the crossmember. The versions of the HD 3-sp that were in F-2's and F-3's has a different rear mount to match the different crossmembers used in those (see below). Likewise, the "SynchroSilent" 4-sp used in the bigger trucks (F-4+) will not fit the F-1 crossmember. No modern 4-sp's will fit either. Once you decide to cut the crossmember, all kinds of possibilities open up. If you cut it, you need to restore the lost structural integrity.
The 48-50 LD 3-sp's and 48-52 HD 3-sp's were floor shift, 51-52 LD 3-sp's were column shift. HD 3-sp's are pretty rare nowadays, as noted above.
