In the US, the 1BA prefix was used inside the valve chamber as an identifier. Valves were changed from plain to rotator type in 1951 but it really didn't change the block. Older style valves can be used as long *** the correct assembly component are utilized. The engine was changed for the automatic transmission in 1951 as well and that was simply a change to the crankshafts so the torque converter would fit. The divorced choke and the dashpot were added to some applications for the automatic transmission. This may relate to cylinder heads and intake manifolds for these cars.
The C1BA is the Windsor version of the 1BA that came out in early 1951. It's not unusual to find a replacement engine in these old vehicles.
Flathead historians:
Our '48 Mercury M47 pickup has an engine casting No. C1BA. Should it not be a C8BA engine, if it were the original engine, of the same manufacturing year as the pickup?
It seems, judging by your posts, that it is very unlikely that our current engine is the original engine. Thanks for responding.
Good point. So there were no "C2BA" etc?Not only is it "unlikely", but the truth of the matter is that your particular "C1BA" block could have been cast nearly SIX years after your 1948 vehicle was assembled. You should understand that "C1BA" only denotes the date of the design exercise. Those same blocks were likely used starting possibly in 1951, then on through the end of 1954 production. DD
