1948 ford tudor
pdgtx4
LONG BEACH
CA
Price
4200
1948 Ford Tudor project. This was a complete car when purchased that has been completely disassembled, cleaned, sanded and/or blasted and painted. White body panels were primed and painted white lacquer to preserve work while project was completed. Chassis has been modified to accept an early 60's Olds/B&M Hydro combination (not included) so the X member has been cut. Installed were Chassis Engineering front disk brakes and Chassis Engineering parallel leaf kit in the rear along with a late 60's Chevrolet Camaro/Chevelle rear end. Included are a stock, gloss black powder coated frame, original front wishbone suspension (less brakes although I may have a set stuffed away somewhere), original rear banjo rear end, radiator, complete 59AB flathead motor that spins freely, 3 speed transmission and a second set of roller wheels and tires for the original chassis setup.
This is definitely a project but a lot of the hard work has already been done. Continue the hot rod setup and sell off the original parts or go stock and sell off the modified parts. I have a bunch of spare parts that can be negotiated into the purchase. Too many projects and unfortunately this one has to go.
