A skip coil is a no brainier, a believer for sure. Probably relieved every starting and running issue I've had for a decade after. Isn't a vw blue Bosch coil perfect for this also?
This is a no brainer. Get Skip to rebuild a 32 to 48 original Ford coil. It will start
your engine and run it hot or cold. Plus Skip has NEVER charged to repair one of
his coils that failed other than a few the ignition switch was left on. G.M.
I thought the 6 volt coil had 1.5 ohm across the terminals. The 12 volt coil had approx 3 ohms. therefore you put a resistor in series with the coil to lower the resistance to 1.5 ohms. The 12v coil with internal resistor should measure 1.5 ohms. i'm also tolt that the internal resistance coils are done by changine the size of the wire internally.
