1948 Flathead head/intake man id
Joebeeker
Good day/evening everyone:
I helping my friend with his 1934 5 Window Coupe of which he removed the 1948 Flathead and replaced it with a 1936 Flathead.
He gave me the 1948 Flathead for my 1930 Ford Huckster project and I need to figure out what I have.
The engine has installed a pair of aluminum heads with the following numbers on both heads:
C7RA-6050-B
NSN
Canada
It also has an "Edmunds" duel intake manifold with duel 97 carburetors.
If anyone knows what kind of heads and manifold these are thank you in advance.
Joebeeker
Heads were originally on a Ford Canada built '47 '48 Merc or Monarch with the C69A engine which had a similar crankshaft to the later 8BA in that it had two oil holes per rod journal and insert type rod bearings. ..B.
