John : I am trouble shooting my Columbia overdrive as it is not shifting out of overdrive. I am doing it alone so it is slow going. It is good to know some parts may be available. When I learn more I will let you know. Any additional info would be appreciated. TKS HH
Take the 2 hoses off the shifting cylinder mounted on the rear. Look
for black oil being sucked from the rear into the hose closest to the
center of the rear, that's the suction hose that pulls the Columbia
in. You can also remove the entire shift unit and shift the rear into
or out of Columbia. The shift arm sticking forward from the rear moves
to the left or right. Easy to remember "in is in", "out is out". When the
arm is moved OUT towards the wheel it is OUT of Columbia and IN
towards the center of the rear it is IN Columbia. If there is black oil
in the IN SIDE the oil seal in the cylinder where the shaft go's into the
cylinder is bad and leaking air and oil form the rear. This leak provides
a lose of power on the cylinder. These seals are available from bearing
and seal companies and should be in stock at Napa, the seal number
is on the seal. The leather cups that are like large pistons in the cylinder
could be so dry they can't move. Put MMO in some small bottle with a
little spout and put a good load of the MMO in both metal tubes the
hoses go on. If you have a vacuum pump you could put a hose from
that on the tubes to shift it. Or a long hose from the intake manifold.
Check and see if you have vacuum on the hoses coming from the
solenoid valves on the head back at the rear. If you have good vacuum
on both when you shift the solenoid the problem is in the back. G.M.
