Hello All
Working on my 48 coupe, flathead 8 everything original. Checking battery voltage while car is warming up and as it reaches operating temp reving 1500-1800rpm,
I'm getting 7.4-almost as high as 8 volts, which I realize is a bit too high. As the car gets good and hot and engine is heat soaked, stopping and starting a few times, I'm only now reading battery voltage, about 6.25V. Seems like something is cutting out as the engine really gets hot and quits charging. What should I be looking at? Could use some input and direction. Thanks
Jeff in Ohio
Jeff in Ohio
