Hi,am restoring a 47 and have the body off the frame.The engine and drive train are in the frame. Problem with the transmission is when the shift rods are hooked up (or not hooked up) can't shift into first or reverse. Second and third shift fine (with rods hooked up or using the shift levers by hand.In neutral if the car is rocked it will shift into all gears fine, using shift rods or using shift leavers by hand.Thank you for your time and help. Mike
