You need to check the fender well opening. The larger pickups may have a larger opening to accommodate bigger tires. The fender may fit , but the bigger opening stands out like a sore thumb. I've seen pickups advertised where the seller has installed the larger truck fenders and you can spot the larger opening right off the bat.
