1947 park/signal lights
coolcoupe
Well I finished all the rear tail/brake/signal light nightmare and all is working as it should thanks to the diagram of that system. Now my right front park and signal lights don't work. Anyone have a close-up diagram of that system ?
Did I mention that I hate wiring.
There are connectors to the right parking light and head light over on the left side coming out of the wiring bundle that runs along the left frame rail. Check those connectins. Also check the ground at your bulb socket on the right side; could be corroded.
Thanks for the reply, I will check on that socket. I just couldn't see both tail and signal lights not working.
Well my park/signal light was my know it all nephew !!! He took a piece of sandpaper and sanded the whole inside of the front housing unit and it lit up it should. I couldn't thank him enough for dropping by.
