Tech_machine
1947 Mercury runs, doesn’t move
I have a 47 Mercury Convertable, rebuilt running. When I tried to drive it, no go.
New Clutch with the rebuild, everything seems to be in order, but it must not be. Shifts through the gears, the wheels turn properly when they are off the ground. But with car on ground it will not move. Transmission seems alright, the wheels turn by hand properly, the driveshaft does as well. The hub lock keys are intact.
Any ideas are welcome, I have some guys locally that help me out, kind of running out of ideas. The transmission is currently out.
I should mention, when you put it in gear and let out the clutch, there is no drag down on the engine at all.
Thanks in advance.
Thanks in advance.
