1947 interior light 1 ton
ahall1
Could some one know where the wire is attached for interior light? I follow across the top of pass door and also how to remove lens ? Does it twist off?
on my 41 3/4 ton the wire was connected at the power terminal on the circuit breaker, not on the battery side. my dome light has a snap ring that is removed to take the lens out
thanks. What holds light chrome bezel on ? The headliner was tore off around the light assy. At first the light wont switch on . then after running engine it will switch on. I can see ground wire @ light. It has good wire and contact.
This sounds like the light in side the cargo area on my panel, I did not know that there was a light in the cab of the pickup. Anybody have a photo to share?
light bezel is actually the light body which is attached to a wood frame attached to the cab structure
the bezel does not come off, but the lens does--look for a small round wire clip that surrounds the lens--take a small screw driver or sharp probe and lift it out. as stated before the bezel is actually part of the fixture--pressed out of on piece of metal then chrome plated. take a flashlight and LOOK real close for the snap ring
yes, the Canadian parts book has it in it. my factory picture is too big to upload, will try to do so when I have the time. Look closely and you can see the factory trim
I will stay with cardboard as keeping everything as was. Thanks for help. I will check in the truck tomorrow for that interior light lens ring
