Having trouble removing the horn ring on a 1947 Ford. I've tried WD40 and turning CCW after pressing on ring assembly. Any other pointers/suggestions?
Trying to get to the button under the ring. The horns work (removed and hotwired) but, when re-installed, they don't. It appears that the wire from the horn relay to the horn button has been pulled out.
I am having the issue getting the horn ring off my steering wheel as well.
It looks like the felt as Kube states has melted and is creating the problem.
Does anyone have a picture of what the is underneath when the ring/button assembly is off the wheel so I get a better feel how to move forward.
Thanks
Finally was able to get the horn ring off, but part of the assembly is damaged. Wondering if the broken ring can be replaced or do I have to get a whole new assembly.
Also it looks like the nut on the steering shaft is wrong , what is the would be the correct nut to use.
Petehoovie, thanks for the enlarged pictures.
TJ, I wasn’t sure if the whole inner assembly had to be replaced as an assembly or if only the broken outer ring was available and then revited back on to the inner assembly.
