1947 ford
bill h
just a question about drive line sealing and fluids. The transmission is a sealed unit. The cover that goes over the u joint (2 halves) i presume is sealed on its own. There is a grease fitting on the cover. Is this for grease or oil. Does the fluid in this cover flow to the rear end or is prevented by a seal in the torque tube. and is the torque tube sealed separately from the differential. thanks for the info Bill
The grease fitting on the u joint cover is for grease. There is a seal near the top of the torque tube to try and hold back the grease from the ujoint (and trans), and there is a seal on both sides of the torque tube center bearing. But a lot still gets past, and overfills the diff.
