N northernclassictrucks Junior Member May 19, 2016 #1 What lube do I use on the steering gear of my truck?
A alanwoodieman Well-known member May 19, 2016 #3 I use a mixture of 1/2 to 1/2 synthetic grease and synthetic 85w90 gear oil. combine the two--I use an old hand held mixer. put this mixture into a squeeze bottle and put into steering box-rotate steering wheel back and forth till the box is full
A alanwoodieman Well-known member May 19, 2016 #4 ps-- I used your parts for my restoration of a 3/4 ton Attachments P9300012.jpg 100.4 KB · Views: 8
N northernclassictrucks Junior Member May 23, 2016 #5 Thanks guys. I knew I would get an answer. I thought it was 90 weight
