racer61x
Recently replaced the rear wheel cylinders on our '47 Coupe.Shoes,drums etc look great,not sure why they didn't do cylinders!!?? At any rate,after pulling the floor apart I removed the master filler cover.I noticed it had no gasket and had been seeping.It's a plastic POS cap.I topped it off to start bleeding and when replacing the cap it felt "loose".Sure enough,bad threads except for the last 2 or 3 which explains no gasket.I dug up a suitable gasket and again,won't tighten.Before I spend hours and excessive money with someone 3000 miles away,I thought I'd give you guys a shot with suggestions or maybe even a replacement cap!!?? We're in Newport NH if anyone local can help.Open for thoughts/suggestions.....Thanks in advance!
