Needing some advice, finding it very hard to find a good drive shaft over here.
The best shaft I have has the front section damaged where the roller bearing runs.
Is there a repair or sleeve arrangement that is being done to the front section where the roller bearing is running.
When fitting the spline to the rear of the drive shaft using the rivets are these heated then hammered or is it done cold. Can you use a bolt instead of a rivet if so what is begin done.
