1946-47 Pick Up Part Identification (#24)
AMC5985
Found two of these in a recent acquisition. Can you identify what they are called?
They mount on the cowl and support the front fenders. That teardrop shaped hole allows the insertion of a carraige bolt at an angle and then it straigtens out at 90 degrees. Then the front fender goes on, then a spring and washer with a castleated nut and cotter pin. Makes for a spring loaded flexible joint for road (or field) flex. A picture would have explained better.
