To my knowledge the extra mounts are on the convertible body, bottom of cowl, inside and bolts to side of frame. Also the front running board bracket is different on convertibles, longer,Has a bolt that turns up against the bottom of cowl to adjust, tip etc for more alignment adjustments .the Frames are all the same for mounding the bodies
