I have seen in a number of posts mention of concourse correct. If I could trouble you all for some of this knowledge please. I have an engine here for rebuild that's going in a 1942 Ford station wagon. This he wants as per factory. What I'd like to know is the colors of the various parts. Block is a 21A, carb is a 21-29 numbered 94, crab type ignition. 81A heads. I believe we're good on these parts. Block/heads/inlet all green? Generator/ starter/ air cleaner black? Water pumps and pulleys?
Nearly forgot this bit, inlet manifold, did the 42 have the same style as the 59A engines?
Any help you can give me in this matter would be greatly appreciated.
Many thanks.
Martin.
Many thanks.
Martin.
