Refreshed radiator and installed new correct hoses. But the Bubba side supports are now too short and probably incorrect anyway. Bubbba had two shackle looking braces that connected with short carriage bolt to the inserts in the radiator sides and then mounted through a hole on the inner fender brace. The large hex head shoulder bolts were not used for anything.
Can't find a pic in the shop manual or a description of what the correct side supports should look like.
Presume they attach to the inserts in the side of the radiator and then mount to the inner fender using the large hex head shoulder bolts and I also presume there was some sort of shackle type movement to allow for the mounting bolts and springs to allow some flexing. But the braces would prevent forward and back movement of the radiator.
Any insights or pics of what I need to purchase or fabricate to mount this radiator correctly.? All assistance greatly appreciated.
