I've got the correct wiring diagram, but it really doesn't tel me why things are the way they are, so before I start disconnecting wires, wanted to check here. Charging my battery and cleaning up some of the wiring on my recently acquired 42 Town Dedan. Bubba has it converted to 12v with a high torque starter wired to a keyed ignition.
When I disconnect and connect the battery cables the horn relay clicks as if it is being energized. I get no horn to the trumpets and the horn ring on the steering wheel does nothing, so maybe a bad relay. But, if i disconnect the realy from the four wires running to and from it, am I affecting anything else? Does power need to go through this relay to someth other component?
I'm tracking down a slow drain on the battery and it may be related to this relay.
