1942 Ford PU
Mike B
Oakdale
Ca
Price
5000
5k or best offer
5k OBO
New brake lines (metal and rubber)
Rebuilt WC's and MC
All lights and Turn signals work
Good running 221 converted to 12volt with Alt
Repacked front and rear wheel bearings with new seals, shoes are fine and adjusted
I have the ****** cover as well as the turn signal lenses and bezels, just haven't put them on.
Made a dash insert for SW gauges, original cluster is here too, but needs restored
Frame is solid
Rewired through circuit breakers...not to factory code, but pretty easy to follow...left a few extra breakers for...extra stuff
Have title for truck as well, yes s/n on title matches frame
Also have the glove box lid as well
Needs:
Tires
Glass
Seat recovered
Patch panels for:
Cowl
Cab Corners
Floor Board
Driver side front fender where it butts to running board...driver side RB will need somr welding too, from age and use
There's of course some dings and such, but no major metal banging....you can see on the passenger door filler...but pretty sure it was jut an attempt to flatten things out, as I can't even tell from rubbing on the inner panel
Also needs proper hood latch/catch
I have Original bed and tail gate (no floor) semi-rough you can have for a trailer...I have a trailer Axle I pulled from an early 50's Dodge bed box trailer, should work fine.
I also have the 239 I pulled from it...was free when I bought the truck in the 90's, but think a valve or two is now stuck.....was easier to swap a good runner in than dick with the 239....all goes...need the room and $ lol
Will add in a low mileage (51 k have speedo to show) 5.0 HO with AOD from a 90 or 91 T Bird
