The vacuum is sealed by two rubber rings that look like O rings. One goes into the timing rear cover, the other in the side of the distributor that faces the timing gear cover. They are usually included in a distributor gasket set. You can use O rings of a proper size top fit the cavity. I haven't seen them sold separately. The whole gasket set is only $8 at C&G.
