speedracer
- City
- LIMA
- State
- OHIO
- Price
- SOLD
*** SOLD*** A nice pair of 42-48 Ford front spindles. Not pitted, just a little surface rust. These accept 39-48 brakes. Good bearing surfaces and threads. If you are using cross steer steering, please take note that someone has cut off and flipped over the end that the steering relay rod attaches to. Now the large end of the taper is on the bottom. This appears to have been done a long time ago and is solid. If you aren't using a cross steer, you will probably cut the end off anyway. $65. Ph. 419-234-2628
