1941 pickup torque tube
fordscript
After totally dismantling my 41 pickup, I notice that the torque tube is 'thinner' at the top end than 37-39 tubes. Does a 41 pickup need this tube for cab floor clearance, or can I use a 37-39 tube? The reason I am asking is because the center bearing on the 41 tube is all slogged out. Thanks for any help on this. Gordon
Why not call Skip and get a new bearing and use the correct tube?? It's not hard to put in if you follow his instructions.
