Hello All,
I have I question I was hoping to get some advice on.
I have a 1941 mercury that I have been in the process of rebuilding and lowering the front suspension on.
I have a original ford axle that has been dropped 2. I also have installed a factory leaf spring pack that I had a reversed eye main leaf made for and removed the leaf right abouve the main leaf. I will be using the factory stabilizer bar. I have installed all of this and when under load my shackles come up at an exact 90 degree angle. I have always been told that your shackle angle should be at about a 45 deg. However I read in the green factory service manual that the factory stabilizer bar permits the use of vertical spring shackles employed with the new longer front spring, since it supplies the necessary sideways stabilizing effect, which the angle mounted shackles previously provided.
My question is this. Does anyone know what the factory shackle angle is on 41 cars? I was hoping someone could shed some light on all this and tell me if I am asking for trouble by not having the shackles at the standard 45 deg. I know the service manual basically says its ok. But I have also had people tell me that front stabilizer bar is worthless and to throw it away. Anyhow Im just looking for some real world advice. In a worst case scenario I could have a new main leaf made that is narrower to get closer to that 45 deg angle but, if I do that Im sure it would necessate the removal of not only the main leaf helper leaf but also the leaf above that. Any advice or words of wisdom are appreciated. Im trying to wrap this up and drive this sucker.
