Randall Hornback
Hi again Kube, a double big thank you for pictures you posted for me on the hoses needed for the oil filter canister hook-up for the 41 Ford. I do appericate.
Randall
Randall
Okay, I'm not afraid to "take the bait". Perhaps because I may be (or so it seems) the only guy that actually has seen the engineering drawings of the oil pan and the respective capacity.Hello too all,and a big thank you for the help you gave me on getting my oil filter canister installed on my 1941 ford. It is on and working, had some leaks at first but all ok now. I know the onwers manual says 5 qts. of oil to full, but is that with the filter or with out the filter?. And on the dip stick when it shows danger, how many qts. to full when car has filter?. All help appreciated.
Randall
The early style hoses and fitting (to fuel pump stand) are on the left. This method was used up until approximately the beginning of May, 1940.Kube: Looks like the early 40 is on the right, and 41 on the left. At least the right shows the "banjo combination bolt-fitting" and its special oil drain line.
Am I correct, or wrong? Thanks for your pics for the two different styles as they show the parts involved.
Lincoln.
That's correct.Hi Lincoln,
Not trying to steal anything from Kube, but the one on the right is what we just used on Randall's 41.
Kevin
I am not so certain I can explain the physics of it. However, i can tell you from numerous first hand experiences, the pressure side MUST be restricted.I have several of these oil filter canisters and all of them have a small pinhole in the center pipe. I haven't measured it, but 1/16" would be a reasonable guess. This should restrict the flow, so I don't understand the need for another restriction. Someone please explain.
Larry Young
Hi Randall,
Do you have the correct line for the return oil? It has what many call a "banjo" fitting on the distributor end. Along with a special "hollow" bolt and a pair of brass washers, a guy would replace the upper bolt on the right side of the distributor. Same bolt that holds the ground strap of the condenser.
That .060" restricted fitting is necessary in the pressure side of the line. Without there WILL be a drop in oil pressure.
I can post a picture of the return line an early '41 requires if you so desire.
The supply line goes between the side of the filter and the threaded hole next to the oil pressure sending unit. In '41 the horizontal hole was to be used.
