ChikaFreak
Hi Everyone,
It's my first time pulling the engine and transmission out of my 1941 Ford. The plan is to get it out for a major over haul this winter. I've started out under the car by disconnecting the transmission mounts and now I'm trying to figure out the torque tube. Is it required to remove the entire rear axle and torque tube together? WI'll the torque tube pull out of the rear of the trans when I have the ball joint cover removed? Please see the picture attached of where torque tube mounts to the trans.
Thanks much! The help and advice is appreciated.
