Feathercraft56
- City
- Hewitt
- State
- TX
- Price
- 43,995.00
1941 Ford 1/2 Ton Pickup in Mint condition. All Henry Ford Steel and everything works as it should. New Fuel tank, Fuel pump, NOS factory gauges, Complete New braking system, includes all wheel cylinders, and brake lines, but made of nickel copper, Master Cylinder etc. Install a $5800.00 Mitchell 36% Over Drive. You can cruse down the highway like a modern vehicle. Installed a near impossible to find Bob Drake chrome Grille and a NOS Ford center grille piece, both cost $5600.00 Has the 1941 optional 239 cu. in. V8 Motor that is fresh and strong and updated to adjustable lifters. Motor is spotless on the inside. Has period correct Hot Water heater that works like a modern one. Still original 6 volt system. Truck came out of a collection and has 37000 miles. All new glass, 5 new Firestone correct Champion wide white wall tires $2200.00 and so much more. Bed is in perfect condition. installed turn signals and the controller is a signal stat, not a cheap chrome job. Painted Henry Ford Black and is near perfect. This Truck is stunning and wins just about every car show it's been in. Have over 60 trophy's. If your looking for the Best this is it. Serious inquires only. You will have to look far and wide to find a truck as clean as this one. Will not answer is truck available. If it is listed, its available.
