Is the truck originally a V8 or 6 cylinder? My understanding is the 6 cylinder used a narrower radiator than the V8 and may not be reproduced except as a custom build.
Griffin is also a good name in aluminum radiators. They tend to do a good job with the external core support and brackets that are so important to get a radiator to fit.
A copper/brass radiator is very forgiving of corrosion issues in an early Ford environment where almost all of the materials the coolant contacts is cast iron, steel, or copper. Aluminum will corrode easily (and zinc is worse) unless the coolant has proper inhibitors and is changed regularly.
Brass/copper might have a high initial price, but changing out corroded aluminum radiators might be expensive.
