1940s Alum. flywheel
Rudy Serar
Arcadia
CA
Price
open
!940s Alum. flywheel with or with insert fo a 10" clutch.
NEED ONE - most people don't look at the want adds. so I
thought I would try this. It use to be great when the F.B. had
the for sale/wanted in one group then at least you got some exposure.
Big thanks Rudy
I have an aluminium flywheel. It is from a '46 Ford if I remember correctly. It has the 12 pressure plate mounting bolts also. The weight is 14 pounds. The ring gear diameter is 14 3/16inches. One of the ring teeth is damaged. Make an offer to wduprez@optonline.net
