raisinhel
40 convertibles have heavier windows with the chrome trim around the glass therefore use a "gear re-ducted regulator. (you turn and turn the crank to raise/lower windows and the windows go sloooow up/down and that is fine when they work smoothly.)
we have fought with a few 40 convert regulators long enough. changed gears, had gears made... aligned the window for free movement, etc...
Drake 40 convertible regulators aren't built the toughest either with a potmetal gear and are not sold separate, have to buy a pair.
anyone use a 2 door regulator in a convertible, or any other regulator other than buying power units?
does a 2 door regulator have the window crank in the same place as a convert?
