1940 v8 timing
fordfixer
Can the timing on the engine be tweaked, with the distributor on the car. It runs pretty good but seems to lack power. Can only get 30 mph in second gear and doesn’t like third gear at all.
If you have the stock distributor the timing is set by moving the slide in the side. It would be best to send it to someone who has a distributor tester so it can be set correctly.
A compression check would be in order. I just replaced an engine, 21 stud, that had 60 psi per cylinder. It ran well but lacked a lot of power through the RPM range/gears.
