modela4shane
I have a question on how to adjust pinion backlash between the ring gear and pinion... do you INCREASE or DECREASE the driver side or passenger side gaskets to move the ring gear closer to pinion to reduce the amount backlash in the gears? I have read conflicting methods, some say driver and some say passenger side. The reason for asking is because i have too much play, .017 lash while checking using a dial indicator. Thank you for any help.
