OK so I think I'm really close to getting my pickup roadworthy. I have a few niggles though that need a more experienced head than mine.
Firstly is there a way to test a brake light switch? The brake lights will only light up when I clip a wire across both contacts. Can it gunk up sitting over time or is it just something that should be replaced?
Second I bought a new headlight knob to go into the headlight switch but it is too short. It appears to be a later, longer switch than a 40 unit. I've googled a little and found the 40 switch appears to be a small square shaped unit. I have one that looks almost identical but doesn't seen to have a 'park' setting and the shaft isn't removable. Perhaps it's for something entirely different though? What are aftermarket headlight switches like?
Third I took it for a drive around the block and when I got up to about 25mph it started making a whirring noise around the gearbox area. It sounded like dirt in a bearing and was intermittent but quite loud. I really really hope not to have to pull a gearbox, any suggestions?
