1940 Pickup Horn/Bracket Numbers
kirkf
Can anyone tell me the full part number for the 1940 Pickup Horn / Bracket?
I'm trying to find one and I'm not sure what the part numbers are.
I think maybe this horn/bracket combo was used right up to 1947?
I've attached some pictures for reference
Kirk
Kirk
577003
577004
577001
577002
Kirk, I hope this photo is of some help. This is a concourse correct horn for a '40. No idea if it's the same for other years.
It took me some searching to find this. Eventually got it from a great fella in New Zealand.
Looks exactly like the ones on 42 to 47 Conventional trucks, I think i saw one for sale in FordBarn, EFV8 club or FB marketplace in the last month....
I'm chasing down two parts right now for my 40 Pickup build,
1. Horn and bracket
2. Drivers side door latch and remote
I went to assemble the door and discovered that for whatever reason the previous owner had saved two passenger side door latches and none for the drivers side.
If anyone comes across either of these for sale, please drop me a note.
I think the horn part should be xxx-13833-x and the bracket should be base number xxx-13831-x, but that would also need a leading number and probably a trailing letter to designate the one for a pickup.
For instance the bracket shown below is part # 1A-13830-A, which is close but not the same as the one for the 40 pickup.
Kirk
1. Horn and bracket
Kirk
577017
For the commercial (pick-up) in 1940 the bracket is 01C-13830 It is unique to 40.
The horn assembly without the bracket is 81C-13833 used on Comm and truck except 11C78 in 38-39-40-41 may continue to newer years.
There are drawings of various horn brackets in the chassis parts books but they lack part numbers. None of the ones shown in the book appear exactly like the ones pictured above there is one that has a 90 degree bracket with two holes next to each other at the end of the bracket.
Thanks you everyone,
I think I've found one with a bracket.
I'll post a pic when it gets shipped.
Kirk
