kirkf
Attached is a picture of my 1940 Pickup Firewall. (This is a Canadian Truck)
It's different than any other 1940 or 1941 firewall picture I've found so far.
This firewall was hacked up by the previous owner who was trying to shove a big block dodge motor into the truck.
Sheet metal on the passenger side from the battery mount down was missing, and has been replaced. (without the strengthening beads being quite the same)
On the drivers side, in the same area we had the original piece of metal and put it back in place.
-This firewall has the upper drivers side strengthening bead go under the voltage regulator. All other firewall pictures I have found this bead stops before the regulator so the regulator can sit on a flat surface.
The wiring cover (kidney) sits in a completely different location from the other truck firewalls I have found. The holes for the kidney are original.
up to the left of the kidney you can see where I marked in white where the wiring loom hole is supposed to be (it accidentally got filled in by the metal working guy)
Questions:
1. Do you think Ford put any type of spacer between the regulator and the firewall to keep it off the strengthening bead, or did they just screw it down and not care it was hinging on the bead?
2. How do you think they got the wiring through that kidney cover? It seems tight between the wire loom hole to get over to the top of the kidney?
3. There are two holes above the accelerator bracket, any idea what they would have been for?
4. What type of fasteners did they use on the kidney cover? Self tapping screws or nut & bolt?
5. What type of fasteners did they use on the accelerator cover? Self tapping screws or nut & bolt?
6. Does anyone have a picture that shows where the heater was mounted on the passenger side?
7. The number P1569 is stamped in the firewall, does anyone know what it means?
8. Does anyone have any reference as to where the starter solenoid would be mounted (hole locations from top of firewall and left side of firewall would be great)
Thanx!
Kirk
Questions:
Thanx!
Kirk
