kirkf
I'm working on piecing together the bed for my 1940 Pickup Project.
Its a difficult task when you don't have an existing bed to work from.
The bed subframe is comprised of two side sub-rails that attach to the bed sides, two metal cross sub-rails and two wooden cross braces.
I've been working out the position of the side sub-rails by assembling it in position on the truck to try and figure out where they go.
At the rear of the truck, it looks like bed side position gets determined mostly by the rear stake pockets. The stake pocket has to form a curve with the rear bed roll pan (The U-Shaped piece at the back of the bed, below the tailgate)
At the front of the bed, there are two lower sub panels.
The position of the rail to the side panel, would depend on how much of a gap there is supposed to be between the subpanel and the running boards.
Hopefully the attached pictures make it clear what I'm trying to do.
(Basically lock down exactly where to attach the side sub-rails to the bed sides.)
In the attached pictures you can see I have a strip of wood as a spacer to hold the filler panel above the running board, but this would mean the side sub-rail is not even to the bed side along its length
Ford must have had a drawing that indicated the position the sub-rail attached to the bed side?
What should the gap be between the side filler panel and the running boards?
Any info anyone has on their assembly would really be appreciated.
Kirk
Kirk
