1940 Fuel tank leak
Chemical / Solvent Resistance Permatex Aviation form a gasket
The product retains effective properties in contact with water,
ethylene glycol, gasoline, motor oil, transmission fluid and sea
water
From spec sheet by Permatex
Reason for using sealer I did not have a new gasket so I reused the old cork gasket.
I used washers under the screws so they are not bottoming out.
