1940 Front Wheel Cylinders
We usually mill the slot in the large piston letting it sit further out in bore so the cup doesn't overlap the miss-drilled porting (and leak) in those "high" quality wheel cylinders.
If you compare the location of the hole in your old wheel cylinder with the new ones; you should be able to see if you rec'd the better parts.
Guys thx for the input. I'll check all this out. Just got notice my Wheel Cyl's. won't be here until Monday now. Hell....in Northern Michigan it could be snowing by then !!
Thx again......Mike
On the Master Cylinder....does the rubber boot go "over" the round thin flange or does it go outside that round flange ?
Thx....Mike
Crap...new wheel cylinder leaks and had to send back and get another. This is going to take awhile for all for wheels !!
Mike
Are you using reproduction shoes? While a lot of the cylinders being sold are junk, there is also a issue that the portion of the shoes on the NEW reproduction shoes that the piston pushes against is made too long and has to be ground down.
