Thomas Sargent
I have a worn-out passenger door latch on my 40 four door. Looks like to remove, the door lock cylinder should come out first to get the square shaft out of the latch assy. But the set screw that holds the lock cylinder in place has a broken off head. Since the square shaft that connects to the back of the lock cylinder and goes into the latch housing will move sideways, and detach, is it possible to remove the latch assy. without removing the lock cylinder and shaft? Just unscrew the latch assy and slide forward? Need some feedback on this idea. Thanks
